because I obviously combined a mess with father-son relationships between the various features and then exchange the order of the two features (before triangular tab for the conicacy) generated different errorsWhy did you do it again?
if it was well built it was enough
the depth of the lamatura if I added the dimension of the thickness encumbrance can be thought as a obtainable quota ? i.e. depth_lamatura= dim of encumbrance - n quotas reportedmissing the depth of the lamatura for the seat of the brugola screw
the diameter of the holes d 12 better to put it on the left view. In general I always put the quotas that define the same geometry (work, engulf, intera..) in the same view so that the operator has pegged under the eye what he has to do without having to jump from one view to the other.
in this case the seat of the screw is quoted to the right and therefore it is good also the diametral quota of the intersection, while the quota of the hole from 12 is to the left and makes it more clear to have also the quota of the diameter
If calculations are not to be made I just have to enter the depth of the enlarged seat of the hole, right?all the taut at the bottom of the flange should be reviewed.
What do you mean? at the beginning of the diameter 32 inside (iin that case it is better to put it close to 32) or at the bottom lamatura than at the beginning of the piece from the left?
I don't know what it is.
is missing at least another quota to define that flange
that to define the lamatura, which is the correct name of the enlarged seat.If calculations are not to be made I just have to enter the depth of the enlarged seat of the hole, right?
In fact, I would like to know what piece he had.What piece did you get?
Don't you have a photo?then the examination consists in the extraction,modelling 3d and putting into the table of a particular of a total and in the realization of a link tree-mode with the bond of the association of the diameters of tree and hub, all in caia v5 and max 2 hours :maybe if q someone interested in knowing the actual part that happened to me, but if it may interest we could speak for private message very gladly =)
really he saidso if I have understood each user at school has brought with it a machine with on installed a different cad from each other user and then you have done the same task in class?
then the examination consists in the extraction,modelling 3d and placing in the table of a particular of a total and in the realization of a link tree-mode with the bond of the association of the diameters of tree and hub, all in catia v5 and max 2 hours :maybe if q someone is interested in knowing the actual part that happened to me, but if it may interest, we could speak for private message very gladly =)
the future engineer snobbaIt's nice to read that after some users got banged to comment and correct drawings now becomes a private thing in a few. they sell siores and siori that we have the secret of flea. . .
