loste23
Good day to all!
using creo ptc
I should create a surface from two sections that are not on parallel planes between them, about 300mm distant.
the first is parallel to plan z, the other is tilted 32°
the surface should be normal on the z floor and end on the second section floor
What command can I use?
Good day
steak
using creo ptc
Good day
steak
