Tekkasoft
And yet another question... .
After working on a project I realized that in fury to save I created many files because of the versioning that pro-e uses when saving files. Let's talk about the wf5 version.
when I went to use the command "file -> deletes -> prec versions" on a .prt file, to begin cleaning, the answer was: the file does not exist in the database. I did several tests on other files created new, made different versions, but nothing to do.
I tried to see if there was something on the online help but only the procedure is mentioned.
depends on some variables in the config.pro file or other?
p.s: the command "file -> deletes -> all versions" works great! ! !
