deleted points
  • Thread starter Thread starter flynight
flynight
Good evening, hear again,
I have noticed that every time I insert quotas appear black dots at a certain distance from them.
if I click on the dot in fact the whole quota is clicked.
because they are very annoying, especially because when I go to print they will see, I wanted to know if there is a way to eliminate them without eliminating all the quota
No, unless you explode. if you have correctly listed those points will be leaning on autocad entities so you should not see them. vice versa you have quoted without using the osnap and this is not beautiful.. .
In fact after quotation I slightly shifted the quotas, for this probably the points will be moved from the entities outside of them.I will try to requote the drawings without moving the quota lines.
Thank you very much
move them for what reason? if you have to remove them from geometry to make them more visible there are the grips, two on the arrows and one on the text of the quota
I'm sorry to contradict you both but the odds dots are seen exclusively on video.
will never come in print, because they are on the defpoints layer (normally for exclusive use of quota points) that autocad does not print, even to want it desperately.
so even if you've quoted a crap, the dot magically in print will not appear
ah perfect! thank you so much! then the problem no longer exists!
:wink: actually the problem exists. if you have quoted wrong, who will take in your design (the electronic version of course) will see it and think... (You put what he thinks).
