meccanicamg
practically
Okay. when you buy a flash drive, to hook it to the press how do you do it? Is there an attack yet? is it standard?
Hi.I've never used the commercial plates, but from what I've understood, you have to get them to work, and in the meantime, you've got to do the relays by following the drawing of the press, or give the design to those who sell the plates and do it as you want. Until now I've never seen a press like the other.
you have to put parallels under the upper plate enough to extract the spherical and pieces, if the press to a hole in the center you can convey them with metal slides.Okay, I get it. One more thing. As the lower plate of the stapler is in contact with the press, from where the sliced pieces come out and the rash?
