meccanicamg
even on my manuals there is a relationship between the diameter of the centerpiece and the plates to be drawn
I think you have no idea what pasta we're talking about. where the underhead of the punch is guided, that is, the cylindrical diameter in tolerance is done in the soft dough. then on you put on the plate hard and on there is still the pasta stampo. the first with the last. the hard one can have the widest holes of the thorns.Well, if punches and pins are attached to the hard plate, would that be plugged to keep all the references of the pieces or not? otherwise when they mount the mold in the workshop, the hard plate could be moved and unchange all references. . .
above the hard plate there is that of the upper standOkay, I was wrong.
from what I understand should be like this:View attachment 38758a giust?
ok, maybe I'm going to say something wrong or too simplified, but: often the "soft" series of plates that fix the hardened pieces. then the "higher lightning plate" is the "higher plate of the lightning rod". and on this staff I. and I don't believe there's no manuals.but this flash plate you say (that in manuals is never depicted), how is it made? It's a plate like the others, but maybe it's on top?
