cacciatorino
if I make notes in a view (assis, welds, etc.), then these are not reported in a possible detailed view, and I have to remake them as head. Is there a way to import them from the original to the detailed view?
Yes, 2010 sp4 32 bitshunter ... I don't remember .. what version do you use 2010?
someone yes and someone no, I have not yet understood what criterion he uses to decide which to show and what not.when you design a component (which has holes for example) the axes show you automatically? because there is an option that allows you to take them inside .. even if I no longer remember what is ...
cmq also to me the axes brought in me shows them , welds and axes added after no ... :/
absolutely true!I insist a little, try to look in the help if dimxpert can do for you, it is fast enough to use.
I'll watch tomorrow, I promise!I insist a little, try to look in the help if dimxpert can do for you, it is fast enough to use.
certainly. what you say is 100% true.with model quotas there may be 2 problems: if the part was made in topdown or extracting the bodies of a welded there are no odds inside it. other times it is necessary to give certain quotas to the features, but others for the construction.
dimxpert is as free as the table, only that you do it once in the model.
I exhume the discussion to know how to display in the table 2d geometric tolerances and reference planes (a,b,... to understand us) made with dimxpert.I rather dimexpert often amount the elements of the model (including rates).
For example, the problem of your other topic's share has solved it like this. :
as it amounts the quotas of the model, also amounts the quotas dimxpert.I exhume the discussion to know how to display in the table 2d geometric tolerances and reference planes (a,b,... to understand us) made with dimxpert.
I can use model quotas but not to display geometric tolerances.
excuses to, but if you write notes on a view, the relative view of detail also displays the annotations present on the father view?if I make notes in a view (assis, welds, etc.), then these are not reported in a possible detailed view, and I have to remake them as head. Is there a way to import them from the original to the detailed view?
I use the release 2010, can you tell me the command to make dimxpert odds appear?as it amounts the quotas of the model, also amounts the quotas dimxpert.
select the view and in 'import options' find what you are looking for.I use the release 2010, can you tell me the command to make dimxpert odds appear?
from the menu: insert -> template elements do not find the option dimxpert
:finger: thank you, with your help and the solidworks guide, which I must say is really good, I solved! :smile:select the view and in 'import options' find what you are looking for.
