Oldwarper
but first what did he do, the spirals of licorice? ?tolerance + - 5mm in diamerto
However the thing that escapes you and the big diameter for which you do not need to cut the head and the tail (then I can bend everything) and the important thing???? ? holder does not want to cut (Add) nada
No, because with the calandra, it turns out to me that the terminals come out to you, depending on the distance of the rollers, but we never used it much.
However I confirm, we also use sw for the simulation of the folds, but in the end the developers must be controlled "from the truth" with the sheet that, presumably, will be used, hoping ceh the supplier gives us a sufficient consistency and in the molds we put all the tricks in order to be able to ovviate to the different characteristics of the materials according to the supply.
by little man, we won't be as expert as you in the displacement, but 40 years of "lamiera" a bit of experience maybe we have it, don't you think?
ah, we haven't come to the head of theoretical calculations yet. Do you give me two reliable figures?
