difference between shell model and 3d
  • Thread starter Thread starter stef_design
stef_design
Hey, guys.
I am doing comparative tests between an analysis with a shell model (sole surfaces) and the same model but with thickness.
If I apply the same materials, constraints and loads I get 2 different results.
How come?
I hope that from the attached pdf you can understand something, cmq the procedure I followed is the following:
3d model:- amount of the model
- I make mesh with 'element size' 2 mm
- material stick (alloy to), load (400 kgf) and constraints (fixed support)
shell model:- amount of the model
- I attach a thickness of 2.5 mm with 'offset type' = top
try to block the scale of stress at a predetermined value for both analyses and assess differences. I think it's a constraint problem.
blocks the scale to 200 mpa and evaluates if the two models are similar. the peak value in my judgment does not mean much
Hi, can you tell me how to lock the stress scale at a precise value?
I don't have ansys right now so I can practice.
