stef_design
Hey, guys.
I am doing comparative tests between an analysis with a shell model (sole surfaces) and the same model but with thickness.
If I apply the same materials, constraints and loads I get 2 different results.
How come?
I hope that from the attached pdf you can understand something, cmq the procedure I followed is the following:
3d model:- amount of the model
- I make mesh with 'element size' 2 mm
- material stick (alloy to), load (400 kgf) and constraints (fixed support)
shell model:- amount of the model
- I attach a thickness of 2.5 mm with 'offset type' = top
How come?
