Hope
do you know how to disable (temporarily) the update of variants (instances) when I make a change to the generic? work with creo 5 out windchill.
I basically have a changing box that was modeled on the generic and then 12 variants such as instances were created.
every time I make a minimum modification to the generic, like delete a section, I create part with the regeneration of all variants (it takes about 2 minutes each time).
I set up in the config enable_autoregen=no but nothing changed.
Thank you all.
Thank you all.
