Thank you.the usual questions to circumstate.
Do you always use the same template, drawing and table, whether when you do it or not? siif you do this once always do it at every reopening of the design and/or solid? siDoes the table have any particularities? no is always the same for each match both where it does and where it does notDoes the axieme have any particularities? I don't think so, but you should tell me what you mean.is the table set on a level? su notes areaif you print the lines you see? I didn't try, but maybe I didn't specify that I'm in the environment together
