Luca-dwg
I would have a question to ask you.
I created a frame formed by unp with the chassis generator. I used "copyed" profiles from the din standard and customized the description using the g_l parameter of the profile length.
I used custom parameters (e.g. =<description> - <material> - <g_l>)
the final result, in description is: "unp 140x60 - fe 360 - 975,000 mm"
I wanted to ask if someone managed to remove, automatically, the measuring unit of the g_l parameter and the "three digits" after the comma.
I'd like the final result to be: "unp 140x60 - fe 360 - 975".
I know that it is possible to remove the unit parameter by acting on the fx parameters of the individual objects, but I would like to avoid passing all the components, one by one, of the chassis generator.
Thank you in advance.
♪</g_l></material></description>
