distinct with generator frames - parameter g_l - eliminate unit measurement
  • Thread starter Thread starter Luca-dwg
Luca-dwg
I would have a question to ask you.
I created a frame formed by unp with the chassis generator. I used "copyed" profiles from the din standard and customized the description using the g_l parameter of the profile length.
I used custom parameters (e.g. =<description> - <material> - <g_l>)
the final result, in description is: "unp 140x60 - fe 360 - 975,000 mm"
I wanted to ask if someone managed to remove, automatically, the measuring unit of the g_l parameter and the "three digits" after the comma.
I'd like the final result to be: "unp 140x60 - fe 360 - 975".
I know that it is possible to remove the unit parameter by acting on the fx parameters of the individual objects, but I would like to avoid passing all the components, one by one, of the chassis generator.
Thank you in advance.
♪</g_l></material></description>
Hello, luca.
You can proceed like this.
From what you wrote, I assume you copied a family into the editor and your library. Did you use "copy to" or "save copy as"? ).
open any part of that family, even from the center contained, choosing "custom"
make your changes both on the parameters on "custom format" (zeri after comma, accuracy) as you mentioned you know how to do normally and on iproperties (custom).
save the part.
Finally open the editor of the content center, in your library, and in correspondence of your family, selections, right-click and "replace family template" and go tie it to the previously saved file.
Let me know.
