door with multiple hinges (2)
  • Thread starter Thread starter Marvel
Marvel
Hi guys, now for some time, about a couple of months, I'm waving to move 2 hinges and a door all together to replicate the real movement of a furniture with 1 door and 2 hinges.
I have tried an infinity of coupling combinations but without success. Maybe I can move the 2 hinges together or 1 zipper and the door, but I can't move all 3 elements together as a real door....:frown:.
Can anyone give me any advice on this?
if then someone wants to jump, in the .rar file attached there are the components to do so... .
Maybe it's nonsense, but I'm in the sea right now. .
Bye!
Mar
flexible you have to do the asses.... and sub-assiem. more angle bond between two values
looking at the couplings, even if suspended for lack of parts, something does not return.
hinges are bound only to the fixed wall and not to the door that rotates. How would they move with these? give him a coincidence to the wall and everything should solve
Hello, guys, thank you for the answers!
you entered the file without the zipper parts........ .
I tried to download the archive too, the hinge file is called "black hinge", if you open it alone and try to move the head of the zipper (the one with the word "fat"), don't move?
the hinges are set as "flexible, and move only to a certain angle. the corner constraint at the moment is only for the door, so that it opens with angle limit from 0° to 120°....
the hinge only moves the part, we call the head, the one with the written "fat", the body with the three screws with the head to cross must be fixed with the wall of the furniture.
However if you want to do a test on the flight, as I did now, if you suspend the door and the right flank (to work better) and couple the plane of the heads of the hinges (written "grass") with a bond of "parallele", the hinges at the beginning move together, as it should be, but just given "rebuilt" they emit various errors of "extreme aids". ...
m
Maybe it's not clear that in the file you uploaded, the hinges are missing. There's just the furniture with the door. It's useless that you make descriptions of what happens. charge the complete axieme of All le parti.
make a pack&go of the axieme because you continue to attach the axieme zip without parts
Okay, I try to reload the .rar file.
Bye!
m
p.s. attached .zip file....we hope it goes...
hinges (the most important part) are not there. to each, looking so quickly, I noticed that you put two limit angle couplers, both on the door and on the hinge and I suppose that's the problem but without hinges
becomes a tern to the lot...
without looking at the file I am saying that from the couplings that I have seen are missing those that bind the hinges to the door.
the door moves with limit angle, if you give a coincidence between zipper and door you square the circle
in this video you can see why it is good to eliminate the couplings of the anta:
[video=youtube_share;uGOJ5_adFoU]https://youtu.be/ugoj5_adfou[/video]
attached the only zipper (as I downloaded it from grabcad a few weeks ago...), hoping that there is everything....
I also ready the pack&go file, but how do I attach it? its extension is not among those allowed. Should I zip it?
Annex 48504
erase this mating... You can't see. .
made....but I'm under the mistakes....
massivonweizen
but did you try? I've tried now, but it always gives me an ultra-definite combination error. . . .
Bye!
Mar
There is no extension of the pack&go. this command allows you to save everything in a specific folder or create a zip. How do you get an extension? then it seems clear to me that if the attached management does not have the extension at your disposal, but allows the management of compressed files, zipping the file is the only way
and how do I do if you don't tie the zipper? Anyway I did it a while ago and it worked
Mar[/QUOTE]
with hinges and of course nn you can give a coincidence couple since there is a distance of about ten millimeters, but of parallelism and it works very well.
I will never understand who to do the function of the guided hole, which is managed through sketch points, does previously a sketch of support (made badly in your case) on which to bind the points of the function. then if you have to make a change of the holes you have to go look for the sketch instead of double click on the function and change the quotas directly.
Here is the video of the door
View attachment 20171104_1641_36.zip
Excuse me, but is there a mb limit to upload files? What I've prepared is 9.5 mb but it doesn't make me load it... .
There's a limit, but I don't know what it is. What is a video?
in the image, taken from the advanced mode of inserting messages, the extensions allowed
You don't need to train anything.
you have already attached it, then you have put the zipper so there is everything you need, as you can see also from the video that I inserted and that moves everything that has to move
