linch
the axial bond of the toothed wheel from the "free" bearing part is assured only by the seeger?
missing the centres drawn in the sunbeds of the tabs. you can put it on or on the front, as you want, as long as you represent it right. Can you draw a whole gearbox? a tree so fine to itself does not mean anything:finger: It's like knowing the alphabet and a few words, now you have to make a phrase of complete meaning... that is the reducer.As for the sampling, I didn't do it because if something was wrong then I had to delete everything and become a pastrocchio.
For the rest of the case, do you mean which part of the case? because to do everything I should do the other 2 trees.
What do you mean by axes in the sunbeds?
the quarry for the tongue to connect the toothed wheel is right to do so "in the middle of the tree" or had to do it on the top in contact with the toothed wheel?(I don't know if I explained)
would be a spacer that and in class it was done like this.the axial bond of the toothed wheel from the "free" bearing part is assured only by the seeger?
I think you have to do it for yourself the whole reducer... then not on two sheets reached with the scotch... Come on.would be a spacer that and in class it was done like this.
As for the whole gearbox, I don't know if we have to do it all, next week I'm going to get in touch
definitely the vademecum for designers and technicians - baldassini - hoepli.small ot: since I have to do the drawing exam, and since the chirone-torncasa does too much talk and few facts, someone can advise me a real bible on which can study and acquire a good preparation? Thank you.
OK, but I don't want to spend too much money, since already the two volumes of the house cost me 80 heuri. So, what do you recommend between the two? I need above all a book that has many examples and exercises done, because the theory is everywhere.definitely the vademecum for designers and technicians - baldassini - hoepli.
the collection of standards uni m1 general volume and mechanical volume are useful.
if you want to study and find the 3 volumes that I mentioned in another post: from project to product - paravia
3 volumes from project to product, have many examples of all mechanics. If you don't want to spend, you need to see what you find on the net, dispenses and notesOK, but I don't want to spend too much money, since already the two volumes of the house cost me 80 heuri. So, what do you recommend between the two? I need above all a book that has many examples and exercises done, because the theory is everywhere.
so would this last book be better than the vademecum for designers and technicians?3 volumes from project to product, have many examples of all mechanics. If you don't want to spend, you need to see what you find on the net, dispenses and notes
Well, as you said in some discussion, I don't want to become an engineer studying on web-based materialIf you don't want to spend, you need to see what you find on the net, dispenses and notes
great :finger: but if you think about it, there is a nuance in my speech... If you take it for your benefit, otherwise patience.Well, as you said in some discussion, I don't want to become an engineer studying on web-based material
this certainly, when I have time I will try to do it, but now I'm especially eager to achieve this taskI think you have to do it for yourself the whole reducer... then not on two sheets reached with the scotch... Come on.
hi snaroz, vademecum is useful especially for practice/procession. I recommend the book that mentioned mechanicsmg. At least you do a general culture.so would this last book be better than the vademecum for designers and technicians?
case and cover, have two different names, are two different pieces. the lid is used to hold a bearing, not to let him enter dirty, not to let out oil. the case is a housing of several mechanical parts and it should also be thought that you can not work from the inside. I repeat, it would be the case that I drew and designed a whole gearbox and you would understand by yourself that certain things cannot be done:finger:I wanted to know another thing about the "drawing" I had attached in post #37 on page 4 of this discussion: on the right I made the case (the one above and under the bearings) and a lid connected to the case through screws. I wanted to know if I need to make 2 separate pieces (cass and lid) or if, always on the right side, I could do a single piece
Here are the corrections.Here, I managed to "talk" something.
Could I know if he could go? if I've forgotten some lines or components?
the two lids of the reducer must be centered with 2 thorns. It is not said that it must be in that view and in that section.always referring to the last design I had scanned, I was told, just below the bolt all up, to place a plug to allow to correctly center the two half.
As for the plug quarry, can I make a blind hole on both the "semi-carter" of the reducer, or on a half of the reducer's case I have to do a passing hole and on the other hand a blind one?
I hope I've explained
