dynamic simulation of inventor
  • Thread starter Thread starter disgnan
disgnan
Hello, everyone.
I would like to ask for help with the following problem:
how to slide a roller on a netting axis from top to bottom, which will swipe in the compartment of a fork of a lever, that this movement rotate for 75° total degrees approximately 35 below and 35 above the lever itself, fixed next, without the lever moving when the roller passes over and exits from the path of the fork.
I have already tried with the transient bond but the lever follows the movement that you want, I also created a surface of one cent to induce the movement of the roller on the surface through the transient bond, but it is not a movement made good that follows the entire recorded surface. i.e. the roller follows the lower part of the fork but not the upper one, i.e. the lever snaps back down to remake the inf. path and not the sup.scorrimento rullo.webpThank you for your attention and for your answers.
disgnan
Good to all.
Thank you for your kind attention and for your immediate response.
I had already examined the wikihelp guide but I had not found any examples of what I described.
we talk about cams with closed external profile, gears, chains, and other, but of different case.
I'm not sure there is something.
I must also say that I have learned to work in inventor with the teaching of a boy who knows how to work in inventor but not in dynamic simulation, and I would like to find another person, online, who would continue teaching perhaps only in case exposed because for now I would have finished the time for this machine and should do other things.
thank you all for the kind collaboration
disgnan
Good to all.
disgnan
do not underestimate the online guide. inside there are all the notions to solve your case without problems.
Clearly, as an example there is not specifically your case.
regarding the online tutor, not because interested but only by curiosity, do you mean for free?
Thank you for the answer.
I would certainly be willing to pay. I paid 15€ per hour the teacher first, max 20€ could go well, not sure 50€. However it is not so indispensable because the machine in many parts moves and it is all right, it was right to have the satisfaction of seeing that everything moved together, but if this had to involve me so much longer, I have no more, and then economically it would not be worth it, much more than I do not care about calculations of efforts, tensions, and frictions, because it is a simple and economic machine.
disgnan
an animation of the constraints I would say it does to your case then.
dynamic simulation is not discounted, especially its interpretation.
if you can find someone however willing to give you lessons at 15/20 euros / hour good for you, but know that current prices are (justly) higher, if we talk about professionals and considering that they are individual, personalized lessons and on topics considered advanced.
Good luck!
I thank you for your opinion, I understand what you say, but at the point where I'm good too, in the future you will see.
Hello, thank you.
disgnan
