disgnan
Hello, everyone.
I would like to ask for help with the following problem:
how to slide a roller on a netting axis from top to bottom, which will swipe in the compartment of a fork of a lever, that this movement rotate for 75° total degrees approximately 35 below and 35 above the lever itself, fixed next, without the lever moving when the roller passes over and exits from the path of the fork.
I have already tried with the transient bond but the lever follows the movement that you want, I also created a surface of one cent to induce the movement of the roller on the surface through the transient bond, but it is not a movement made good that follows the entire recorded surface. i.e. the roller follows the lower part of the fork but not the upper one, i.e. the lever snaps back down to remake the inf. path and not the sup.
Thank you for your attention and for your answers.
disgnan
Thank you for your attention and for your answers.disgnan
