electric motor
MARCOC
Good morning
a three-phase motor has data injectors
2800 g iri/min
1.1 kw power
3.8 nm pair
diamer tree exit 19mm
if I want to know the peripheral force on the tree and just apply m=f*b
and then get 400n
Thank you very much
i had written performance because i thought that eih64 was referring to what "dead". i ask for venia!
in practice sec eih64 the "arm" is not the radius bensi the diameter to what I understood!
we are not on the 400 n... it seems clear
You may be right, but it depends on how you interpret the initial question.
Imagine tightening the tree in a clamp. If you want to know the f1 force that has to exercise every single jaw, of course this will be f1 * d = c and then f1 = 200n. Thanks, the jaws are two...
If instead, as I seemed to understand from the question, we have only one force, think for example to a grinder, approach the piece and snap it with a certain force, the force (tangenziale) on the piece will be such that f2 *r = c, and then f2 = 400n as we said.
What's wrong with you?
however the f1 are 2 and agree on the axis, therefore total 400n
The initial conditions are:
3.8 nm pair
shaft diameter output 19mm.
then everyone sees how he wants
3.8 nm pair
Yes, like the sex of angels.
you are talking about the input data, not the question.
and then get 400n
the question is "the peripheral force". peripheral force is 400n. point
"But if I attack two diametric forces what happens? "
Okay, in this case the forces are two, you have the possibility to increase the arm, and then they will be each 200
"But if I apply three forces and a tilted torque of an alpha angle to the axis of rotation, and all immersed in the molasses? "
the answer is 42 (:tongue:)
