genesis1975
All that is reported always puts it in the main destination folder. . I should go to the options now and say that you don't load the reference documents anymore... what option do I have to put?
No, I don't remember. you opened 150 posts on referencesNow you remember that I had made several sketch configurations to give the coincidence on all the assemblies and to be able to bind them?
quindi? in The debate I also wroteYou told me.
e al post #26a parametric cad requires a good organization of files and references and you can not think of doing things to good thinking of saving time to make configurations, to remake a particular, to use logical origins and plans, to structure folders... then go out holes the messes that make you lose the triple of the time you thought you had saved
I no longer know how and sauce explain to you the logic of rrimentsthe pack&go makes a copy of the selected file, together or part, including all references in it.
if it is a set will copy all parts, drawings (if selected) and any assemblies with shared references (but not the parts contained in these possible assemblies)
if you draw a part you will copy the drawings (if selected) and any references to other parts or assemblies (in this last case you will copy only the assemblies and possible share)
If you want to open the axieme, it has nothing to do with the references included in the pack&go.the other day I gave that option to open beyond the one chosen, all the documents in reference....and then the pack&go opened me also the other assemblies...can this be the motivation?
I have to remove the spuns from the documents you don't want to upload.All that is reported always puts it in the main destination folder. . I should go to the options now and say that you don't load the reference documents anymore... what option do I have to put?
is explained in the guide to what you needoptions > external references > files in reference
