In my pocket I don't have it.... in the refrigerator I'm done with the salami....you put the pieces of iron on it?Yes, but post a photo of one of these torpedoes.. .
but the diameter of the tree must be less than 15mm hold?solar gear must be integral to the input shaft
ah understood has the front pin where the toothed wheel goes and then the upper diameter shaft.deve essere a roba tipo questa
no, what front pin??? This tree and the gear are one piece!ah understood has the front pin where the toothed wheel goes and then the upper diameter shaft.
Sorry I looked in a hurry, it seemed like a profile on a pin you're right? ?no, what front pin??? This tree and the gear are one piece!
I understand now.no, what front pin??? This tree and the gear are one piece!
then maybe you can use a "millerighe" instead of a tab.Thank you very much.take a round larger than the gear head diameter and return the bearings' jokes and the transmission hub. then put the piece on the toothpick and cut the teeth from the trunk.
the diameter just by side will be something smaller than the bottom diameter of the gear.
It will look like this:View attachment 58155then maybe you can use a "millerighe" instead of a tab.
I would do:but I have a doubt, the sun from z14, module 1.25, width 50 mm, resists to 36 nm at 4000 rpm?
was verified both by me and by him.but I have a doubt, the sun from z14, module 1.25, width 50 mm, resists to 36 nm at 4000 rpm?
we can not exceed 100 external diameter.I would do:
propeller 15°
band 30 mm
module 1.75
In this way, I realize that you are not in the outer diameter imposed by 100 mm, but if we do not want to break the reducer shortly.. :
if it has beta angle of 15th yes. if it is straight teeth not.but I have a doubt, the sun from z14, module 1.25, width 50 mm, resists to 36 nm at 4000 rpm?
