gemini179
Good morning to the whole community cad3d, I quickly expose you my problem:
I ask you if it is possible to create recognizable blocks from autocad (of each single catpart component of a catproduct) by exporting a catdrawing in dwg.
in practice saving a catdrawing in dwg I can get only one block losing all individual entities. by exploding this block in autocad it is not possible to understand which lines belong to one part and which to another. this would lead to create a single dwg board for each catpart and then assemble it in autocad, you will understand the considerable waste of time.
I hope in a possible solution
Thank you in advance
