esportare catdrawing in dwg - problema blocchi
  • Thread starter Thread starter gemini179
gemini179
Good morning to the whole community cad3d, I quickly expose you my problem:
I ask you if it is possible to create recognizable blocks from autocad (of each single catpart component of a catproduct) by exporting a catdrawing in dwg.
in practice saving a catdrawing in dwg I can get only one block losing all individual entities. by exploding this block in autocad it is not possible to understand which lines belong to one part and which to another. this would lead to create a single dwg board for each catpart and then assemble it in autocad, you will understand the considerable waste of time.
I hope in a possible solution
Thank you in advance
Good morning gemini179
As long as I'm not a 2d expert, then take these instructions with the springs, waiting for someone more experienced...
not knowing for nothing autocad I do not know what elements he recognizes.
layer: in caia you can assign them to object 3d but I don't know if you can pass them to the 2d directly without clicking on each single line.
colors or types of line if they pass through the dxf or dwg, when you go in 2d, dx key, view .... object , other menu , overload properties . at that point you can define for each object, without clicking on any object , if to do so instead of continuous ....
Could it be a help?
