excessive file size
jim78b
I have always worked without layout today I realize that creating a view port and putting on the table in the layout the file takes 1 mega and passes of space .!possible?
does not depend on the layout, depends on how clean your model is.
I just created and saved a new design (empty). weighs 180kb.
then I created a layout, and inserted a viewport. saved again the file weighs 173kb (less than vacuum)
As soon as I deleted viewport the file is reduced by a lot!
so it is not the modell9
I found out what it is...the paper is a dynamic block that if you click you can choose various options. I can't remove it.
I found out! is the jpg of the logo!!! occupy 700 kb!!
now maximum are 265 kb files!!
then you hold it and keep the weight that it has.
otherwise if the only variant is the language you create, always with attributes, one in Italian, one in raw, one in Gaelic, one in Breton, one in Castilian and one full of randomly fished ideograms on the net that so no one understands that they want to say
However 1mb is not so much to manage.
I know but as they are many constructive ...cmq thanks you are always there to help me!
If you work for external customers is a discourse and you have to bend to their rules and models, but if you do internal work with your/her own model, cartiglio, logo etc. you/you should establish guidelines and lose a few days to optimize the above-mentioned models by scoring/vi the magagne or criticisms that come out, like this or that of the blocks of the other time, to always better finish the procedures. If everyone does a little shit he wants. or if you are alone today you wake up right and do one way and tomorrow left in another, then you lose a lot of time to squander and ask for explanations (the blasphemies are always free and said in progress)
Are you sure it's a jpg?
if it were a correctly inserted jpg, the jpg (outside) would weigh 700kb and the 300 file.
I think it is an ole (an image attached in autocad with copy/paste) and if it weighs only 700kb you are lucky.
and bo I only know that I have rinseed lighter copy and paste.cmq max w. you are right everyone does what they want and you work badly!
