jim78b
I have always worked without layout today I realize that creating a view port and putting on the table in the layout the file takes 1 mega and passes of space .!possible?
As soon as I deleted viewport the file is reduced by a lot!does not depend on the layout, depends on how clean your model is.
I just created and saved a new design (empty). weighs 180kb.
then I created a layout, and inserted a viewport. saved again the file weighs 173kb (less than vacuum)
hiThen you explode it.
that probably instead of being scaled with a paint program they climbed it in autocad decreasing its size in mm but not in byteI found out! is the jpg of the logo!!! occupy 700 kb!!
Exactly!that probably instead of being scaled with a paint program they climbed it in autocad decreasing its size in mm but not in byte
and bo I only know that I have rinseed lighter copy and paste.cmq max w. you are right everyone does what they want and you work badly!Are you sure it's a jpg?
if it were a correctly inserted jpg, the jpg (outside) would weigh 700kb and the 300 file.
I think it is an ole (an image attached in autocad with copy/paste) and if it weighs only 700kb you are lucky.
