Giordano85
excuse the terminology used. I wanted to create a layer and not set it as a current. I tried to do everything, but eventually when I choose the layer simply tells me that the "current layer has been disabled" and everything remains as it was before.
I have proceeded so from the beginning:
1. I created the pippo layer and made it invisible;
2.I exploded all the drawing and modified the forum you proposed to me as follows:
(setq aa (ssget "x" (cons 0 "attdef") (cons 2 "number, terminal, 3lev_ins_data"))))
3.digit send and then selez and !aa. I receive the following message:
select objects: !
<selection 10c="" set:="">found(s) 463
4. That's where I have the problem. then selecting the pippo layer that was hidden, I receive the message: "current layer has been disabled."
I hope I've explained quite well! eheh</selection>
select objects: !
