Hilip
Good morning, I have the following problem:
I have several imported cone logs like *.iges by autocad.
I collect a 3d sketch to recreate a single cone trunk, adding the geometry of the major base and the minor base and I carry out the 3d model as a supericie via loft.
why does it also generate that edge/line highlighted in the image? It is a problem because when I create the sheet it gives me how to cut the line geometry and I don't need the cutting geometry on that line but exactly on the other side mirrored.
How can I do that?
How can I do that?
