Dador
Good morning to all!!! and down snoweee !!!
there has never happened a .par file that you can not open in environment part. if you try to insert it into a draft, this message appears "impossible to create drawing views for errors in the geometry of the model. a common cause is the wrong geometry of the imported model. revision the template file to resolve errors in geometry." that if you try to insert it into an assembly, this other message "impossible to insert the part".
but I can open it using "view and annotation"....
I don't know how to heal him! !
Thank you so far for your help!
