Robert Tutu
good morning to all, I should draw a plate with an aspiration system, practically it is an 8 cavity mold, each of which extracts a piece (as you already know) there is also the materozza that falls during the extraction. In practice I should design this plate which should collect all the materozzes that are discarded during the extraction process in a single tank (let's call it that). plate height 446mm, plate width 246mm, plate thickness 35,90mm, interassess between the holes 80 mm and diameter 68 for each cavity. the plate should not be as thick as the mold would no longer go in line.
attach plate image with 8 cavities. How would you do that?
