fold compensation
MARCOC
Good morning, I need clarification
from inventor's help I read the following
the fold compensation equation allows to determine the total length developed by equation:
ltot.
v=(is the result of the calculation of the tolerance of the fold. )
in inventor, the tolerance of the folds is calculated by the following equations
lba=equation +v
lba=(it is the length of the fold tolerance. )
so the v as I echo it if I have no lba....
someone can help me understand
Thank you very much
thank you very much laura888, but my problem not as you calculate a development, but just understand what it means inventor by lab and v
and how can I get a lab value if I miss v, one of the 2 variables I have to speculate? ? ? ?
"the following equation is used to determine the developed flat pattern length using a
k-factor:
total length = leg 1 + leg 2 + bend allowance
the bend allowance is calculated using this equation:
ba = π × (a/180) × (r + k × t)
in this equation, the abbreviations have the following meanings:
◆ ba = bend allowance
◆ a = bend angle in degrees
◆ r = inside bend radius
◆ k = k-factor
◆ t = material thickness"
