PiegatoreSolidworks
I'm here to explain to you my doubt that I haven't solved with the help or even on tutorials. when I am creating a staggering to be able to couple 2 different sheets are always to "combat" with the command in question, because I never know if the distance between the two folds that creates is inherent to the matrix that I am using to create the piece.
now I was wondering: Is it possible that you do not use the command well or to solve my "problem" I can only use "flat size" function?
thanks for the attention.
