function "expansion" on sheet metal
  • Thread starter Thread starter PiegatoreSolidworks
PiegatoreSolidworks
I'm here to explain to you my doubt that I haven't solved with the help or even on tutorials. when I am creating a staggering to be able to couple 2 different sheets are always to "combat" with the command in question, because I never know if the distance between the two folds that creates is inherent to the matrix that I am using to create the piece.
now I was wondering: Is it possible that you do not use the command well or to solve my "problem" I can only use "flat size" function?
thanks for the attention.
I don't keep understanding, I want to help you, but I miss something.
Can you do an example of the project and what can't you get with the above command in the design/coupling phase of the two sheets?
I, who have a fold, understood:
in practice he would like to manage the distance of the 2 folds because, as known to the fold, that distance is important when you have to bend a
sheet with z profile like that placed by bending machine.
Look at the attached image, he would like to manage that share.
Good mike, you got it! But do you think there's a solution to my question?
I think you need to check the corner with an equation.
in practice after you have done your nuance you look for the angle quota go to change do add equation.
then snap the button of "arcsin" in the brackets write
value staggering / piego you want to get and he gives you the exact angle.
Try to see the attached pictures if you're having trouble calling.
I much more simply do a staggering "casereccio" as you see from the image (powering to use the mike mold)
If there are limits in the execution of certain templates and the designer must take into account, here is not solidworks that must do it but the designer, through the tools he has available.
How does solidworks understand the minimum threshold between the two folds?
in your case is the used quarry that precludes certain distances.
This is the 3 solutions, starting from the simplest :
1 ) your with sensor control
2) that of ciarly with sensor control
3 ) Customized edge sensor between two folds
However both staggering function does not have the requirements that I was looking for, at least I seem to understand. So, if I've been so long, I prefer my home solution!
Thank you all.
