funnel on cylindrical solid
  • Thread starter Thread starter Giacomanu
no, it is a cylinder with various shapes (made with lathe to plate), which then we put in the press and with a mold we make these funnels.
Thanks, bye.
Also I can ask you another information, I imported a file in iges, I closed the various faces, I sewed them, but remained a set of surfaces united, I would like to close it solid, how do you do??? Thanks again
you should look if under "preferences--> modeling" has the option set on body and not on sheet
if you are already on body and did not become it then it means that there is some hole then you have to do under "analysis--> examine geometri --> activate boundary " and from there it highlights if there are holes
