geometric tolerances
  • Thread starter Thread starter Christian_spinelli
Christian_spinelli
Hello everyone,
I have a problem with proe wf3; if I impose an axis as a reference for a geometric tolerance, then, in the table, I appear in all the views in which I show the axis.
How can you make it appear only where I want?
Thank you very much.
but if I want some references and not others in that view?
in the attached file, for example, I would like to see the reference y in the right view and the reference x in the left view.
using levels would not be possible, right?
from what little I learned in this period, if you create a reference for a geometric tolerance of def. appears on all views. to eliminate it in the views where you do not need I went into the annotated tab, then in the drawing tree you can notice that for each view the reference created. All you have to do is right-click in the views where you don't want me to appear.
p.s. erases, does not eliminate otherwise it takes you everywhere
you know that the indication of tolerance, such as 0.1 parallelism with reference to can be read both horizontally and vertically. I want to know how to put it vertically
