grasshopper
  • Thread starter Thread starter Cianfri
Cianfri
Good morning, is anyone able to use fathopper willing to give me a hand? I never used it but now I'm forced to use it, from tutorials something I understand but I can't apply it to my case!thanks
I put one of them, allowing me not to dump the horse yet.
It would be useful for my purposes to have a rhino function that allows me to create sections of a closed and tapered surface, spaced with a variable step, extruded in solids to give them a thickness. It doesn't seem complicated in theory, but would someone already know how to do it?
I can easily put an example to you, then the definition
you can apply it to the geometry of your interest. .
a single doubt that means extruded sections in solids to give them a thickness? ? ?
clarify this aspect and I think I can help you
to the
I have to create orders, so I usually create an intersection of parallel planes with the surface, I generate curves, I extrude them to give them thickness. Just say.. because I should also make lightenings.
I actually managed to do this but a comparison I don't mind. Moreover the surface is no longer editable or anyway I would like to remove that red color from the surface. .
missing the photo
I will see from the pc thanks, however I do not start from a surface of revolution, but from a form/surface variable.
Thanks to the, still not seen cause study, but I will let you know, thank you.
do you have a manual in Italian of gh? an online lesson would be too :d;)
