grip of linear parameters that do not activate
  • Thread starter Thread starter alex.m74
alex.m74
I need to create some custom dynamic blocks but I am not having positive results. The problem that arises is that the grips of linear parameters are not activated. I will explain a little more in detail the problem.
I create a rectangle with the appropriate command (retangle ) , I turn it into a static block from "i insert-crea block" I give the name , I establish the insert point , select the object and doppa ok . until then all right . to turn it into a dynamic block I click twice on the block and within the dynamic blocks editor , in the same click
because it is not enough to put the parameter and give it a name, but you also have to set the actions.
read this tutorialhttp://www.lorenzomorandi.com/news/blocchi-dinamici-autocad
hi massivonweizen, first of all thank you for answering me. I fully agree with what you say, this however is a problem that is presenting now because about a month ago I made other dynamic blocks without having found hitches. Now I don't know what the problem is.
I would like to put in a video of my desktop while I perform these operations but I don't know how to insert it, if someone gives me the right how to do it.
As I said, I only have a flour, so I can't help you.
in your first post you described all the steps except that of the actions, from that I thought I didn't put them and I indicated the ink of the tutorial. If you wrote that everything was different to you first and I would ask: what changed in the meantime? update software, pc, driver or other?
for the video go in advanced mode of the message and attach, if you do not accept it you have to zip it
Unfortunately I can't upload the video, asks me to insert a link , I should first upload it to youtube the problem is that I don't remember the access data to my yt channel . if there is someone who can help me with the directions I gave :frown::
What part of this message do you not understand?
the problem is that the message I have perfectly understood what you want to say, the problem is that I can't upload the video . He asks me to insert a link . Now I try to zip the video with winrar and try again .
the other solution would be, upload the video to a youtube channel and post the link , but I would rather not opt for this solution .
I apologize if I insist, but I need to find a solution to the problem, I see that in this section there is no one who can help me, can you at least tell me if there is a section in this forum where I can find someone who can help me?
Are you using visibility states? attach the block
Thank you for the answer, on the previous page I attached a video made while I create a block and give the parameters, could that be useful to you? If I don't bother too much I would ask you to take a look at him maybe from there you could see something . thanks again
One thing I noticed last night is that if I try to take a dynamic block from the palette and I click on the grips they activate regularly , then I try to make a rectangle and I create it as a block , I give it the parameters and I close the block editor , when I click on it the grips do not turn on, if I click on the block of the palette the grips are activated regularly .
But I didn't realize that you didn't even put in an action... what the hell needs grip if you don't have to do anything?? associate an action and you will see that the grip appears. without actions it is correct that you do not see also because it does not serve a beloved fava! !
the problem is that they do not even activate by associating the actions.
in the attached footage do not associate anything. I can rely on that. I don't know what to say.
