re_solidworks
I don't know other solid modelers. .
solidworks sì....
Do you know that your post with the controversy about the nisba did not understand?I assume that the development of the helid can be done by keeping in mind what you said te tarkus.
nisba let me do it is not a constructive answer and suitable for this type of forum, also because I think we have to arrange all with the tools we have in hand.
and if you are able to arrange inventor a hand on the development of a helicoid gives it to you.
cmq here is my dish. (helicoidal) obtained with inventor from a helical crumpled with the sheet module of inventor pro. 2015
View attachment 40715View attachment 40716greetings to all
hi I apologize I did not want to make controversy, cmq the development does it on the length of the skeleton of the helicoid.Do you know that your post with the controversy about the nisba did not understand?
nisba, ciccia, fuffa, I don't know how it says in your parts, it just means that inventor doesn't, indeed I correct myself, I can't get him to do it, despite years I beat the boss.
I didn't even realize if you were able to develop a helix on the perpendicular plane to the axis of revolution (as asked who started this discussion).
if you know how to do, post an ipt file rather than pictures.
for the "non-automatic" I have long been equipped with a file where I create the only one helid at a step+ a second file that fishes the parameters from the first, applies the mathematical formulas of the case and creates a face in "lamiera", with the size of the development.who:http://www.cad-notes.com/automate-flat-pattern-of-continuous-spiral-flight-design-using-ilogic/is not automatic, but for those who have placed the question could be useful
is true laura the coclea element is not an exact development. indeed it is wrong and it is absolutely right what you have put (that not automatic).thanks tarkus for sharing (can always serve and works :biggrin
I am not convinced of the development of the external dish of aptitude: ok, in the case of the plate worked, it is not so for the auger element because it is the definition of the side to be, according to me, conceptually wrong (in fact the flat development of the auger element is a rectangle... ).
good, I just tried with a helid to make with a plate aisi 25x8,I assume that the development of the helid can be done by keeping in mind what you said te tarkus.
