spinner3000
you say that without correction it could be okay, that is, I draw the tooth with the width indicated to drawing?
you understand perfectly, I manually put the game on the sides to reach the required size of the tooth thicknessthen, you use the shape that comes from kissoft but instead of making the tooth wide 34.69 as you drew the do wide 33.87 as the customer requested, you eat it away 0.41 mm by side.. I don't know if you understand me. It's late and we're a little fused!
to understand if there is the profile shift I did so:question.
How did you find that it is 0.25 profile correction?
the only thing that makes me say that despite everything can be that it is only shifting as it says pietro, is the fact that the outer diameter of the wheel is that of an incorrect wheel with x=0.you say that without correction it could be okay, that is, I draw the tooth with the width indicated to drawing?
I want to try to sum up and I ask for confirmation to mechanicalmg if you agree:the only thing that makes me say that despite everything can be that it is only shifting as it says pietro, is the fact that the outer diameter of the wheel is that of an incorrect wheel with x=0.
So he goes to erode his side as long as he doesn't fit.
it will be so, but it is definitely not a choice among those of tooth optimization. But it is seen that the power transmits it as a guarantee.
So, assuming that you do not detach yourself without correction, how do I get the measures indicated?the only thing that makes me say that despite everything can be that it is only shifting as it says pietro, is the fact that the outer diameter of the wheel is that of an incorrect wheel with x=0.
What we said this night...So, assuming that you do not detach yourself without correction, how do I get the measures indicated?
What do you mean by shifting?
Just like you did.I want to try to sum up and I ask for confirmation to mechanicalmg if you agree:
the correction is made to improve the strength of the tooth, to avoid detachment sub-cutting or to respect an inter-compliance imposed.
shifting, that is the axial shift of the creator, is done to remove material from the sides of the tooth to ensure the proper functioning game. in this case the external diameter of the teeth does not change compared to the theoretical.
What a good thing? The chip is coming out of the monitor.the disc cutter with inserts for grinding could be the one that I attach the drawing to you.
right by curiosity, do you take care of teeth?the disc cutter with inserts for grinding could be the one that I attach the drawing to you.
It is not right because it has, rope should not be 25 but 18,6.Hello everyone
According to the indications you gave me, the results I get are these.
then keep us updated with the new data, so we also practice.Well, I'm sorry, I asked if they sent me more information. .
so it seems impossible to achieve correct results??
come si fa lo shifting con kisssoft?then keep us updated with the new data, so we also practice.
Anyway, you didn't make the shifting, otherwise you definitely got out right. he went out.
attention the altitude 33.72 you have it at a height of 18.7!Hello everyone
you have to go into the game management of the tooth jn. with the pdf guide installed locally should explain how to do....in reference profile or in tolerances.come si fa lo shifting con kisssoft?
Currently, after long activity, I am dependent inps!right by curiosity, do you take care of teeth?
However the concept is that will be long as processing
