Jeffcott
Hello, everyone.
I designed a tape for a weigher with the following specifications:
- tape width 350 mm
- tape length 500 mm
- total weight tel 300 g
- teflon tape on steel top
the same slides on two rolls diameter 30 mm
I was then given a cc engine with the following specifications:
- power 60 watt
- number of laps 3300 rpm
with relative gearbox characterized by:
- number of laps 536 rpm
- i = 6
- performance of 0.9
I then finally determined the max transferable weight on the tape that resulted to me equal to 5 kg.
I then take advantage of the forum to ask confirmation to you all and if possible its steps for verification.
- tape width 350 mm
- power 60 watt
- i = 6
