sampom
depends on the material and its thickness. This is a typical question to ask the supplier. ask that "elastic stretch" and that preload should work that tape (but on a minimum length as your variation will be irresistible). theoretically consider it "rigid", so the development will be fixed at the right tension to have the 2 branches "in floor" (on long and heavy tapes in the return branch there will always be a "spring" to support with crazy rollers, but it is not your case).Forgive me the question, perhaps surprised. for the development of the cloth I limit myself to the sum of the diameter of a roller for the double of the [D(rullo)+Interasse x2] ?
how do you take into account the fact that the tape will be tense?
I usually use polyurethane (always with support base "in canvas") and calculate the average development (eye to the thickness, the outer diameters of the rollers are increased by half of this) with all the logs and mobile axes placed halfway, rounding then by defect. the race/position of the registers also depends on how you planned the assembly/disassembly of the carpet (if closed ring "saved").
I repeat, for safety I would show a wrapping scheme to the carpet supplier.. then made the first experience is acquired automatically.
Marco:smile:
