import stp or create new together with shaded display style with edges
reggio
hello, when amounting one step or another format in sw or
when on one side or by a subaxieme I create a set,
the result I see in the new together is always
with display style=>shaded (without edges)
I would always prefer it with display=>shaded style with edges, by default, is it possible?
could depend on solids that optimizes graphics to improve performance.
or is a template setting that you use
If all the fatigues would be in a click...solidworks does it because the graphics card should not go crazy x a step.
.... mah, today I imported a step that eventually became a set of 41,000 parts (including balloons), I do not think that after all that fatigue, it is an extra clik, that does not weigh, can "heave" ... of the made series 41.000 we also make 41.001 :d
jokes aside, ending the import with or without edges the model moves identically, only that with the edges I can understand, without edges is a useless cluster of colored shadows ...
anyway, thanks for the support :d
on the fact that without edges you do not understand how shape has the body I give you fully right.
However, there should be a setting somewhere to set because that I remember in the 2004 version did not disappear the edges. or what do I remember wrong? ! !
... nothing, there is no bit, even rebooting sw the situation does not vary:(
I'll keep it that way... thank you anyway!
