Atreiou
it is trivial but I find no solution
I have a part that composes an object, which consists of several imported parts, 5 or 6, but the object is not oriented as I would like,
attempt 1
with the command moves wheel arrival to place it to 90% using the planes and faces
then when I try to make the last move, using the average point of a segment to bring it to the desired plane, the point makes me select it but does not make me select the plan.
attempt 2
I create new plans set on the points and faces of the imported of my interest
but with moving and turning the planes are not selectable to carry out the movements or rotations, I also tried to draw sketches to be able to use different middle points, but it did not work
Is there another way of orienting or changing the original coordinate system according to the import ?
attempt 1
attempt 2
