I don't think because the same people who sell us the pcs are the same ones who sell us invetor... :biggrin:I just can't understand why it's difficult to open relatively simple files.
I also tried with different formats but the result does not change.
from a few months I try to find a solution, who manages the pcs says that the fault is of the software, that sells us the same from the fault to the pc
the result is that every time I have to import a file are pains.
If someone has a suggestion to solve this......
non trivo dove impostarlothe conversion ratio, where do you put it, external, internal or both??
Where do you find these settings? Have you tried to change them?theseView attachment 43905It is not that there is then much to set up.
I opened it without problems with 2014, you did not let install the old rel. ?hoping not to open one of urgency:wink:
Really?!? .. with old version do not trouble the steps ....I opened it without problems with 2014, you did not let install the old rel. ?
It's not a definitive solution, but at least you don't go crazy.
later I try on 2016 and see if I find a few sets to set up
