impossible step to open
I haven't worked there yet because I was absent, discarded the backwards try to put me behind
I use the linked option instead of importing all geometries, once saved the file becomes lighter, so there is also the possibility to update the linked file in addition to the ability to manage (load or not) the various parts or sub-axis of the step.
doing so I can import even 100-200 mb files, it certainly puts us a little to the first import.
if you place the solution could be useful to others too.
the technician told me that it was the fault of the custom colors created for the materials that we work here, using a new installation of inventor the problem did not exist. You see that it went in crisis in theassociare colors that in the step did not exist.
I personally use another system especially for large files.
or via the "stepin" command typed by autocad-mechanical .... the import speed is incredible!
at this point (species for layout management) gates everything I don't need, then there is the possibility to further simplify using the usual Boolean operators of "somma".
Finally I re-export everything and embroidery from inventor.
:finger:
