impossible to extrude
  • Thread starter Thread starter DilanDesign
DilanDesign
I am trying to perform an extrusion to create a plate starting from a sketch made half by a projection and the other half by simple lines, the problem is that when I start the command already the extrusion part highlighted of red therefore some problem there is for sure, at the end of the command appears the written "crea extrusion: detected problems during the execution of this command.
thanks to the pious soul that will help me! :wink:
as not said, the error was in creating the sketch directly on geometry instead that create a new component and then go to project the underlying geometries!
Thank you!
