Impossible to save dates
  • Thread starter Thread starter marcofa
marcofa
from some time and randomly it happens to me that I cannot save the data with this error "impossible to save the data. problems with srittura on file system". but to the second or third attempts the rescue went to good end.
Now it happens that I can no longer save the cat files, every time the message appears and in the folder you create a file
.56f898a9b42200001598d25eae0500000 each time different.
other programs save regularly.
I tried to create a new folder and save there the rejected file: He had, the first time he was saved, but if I try to save a second time he refuses.
I think it's not a PC problem, but just a cat.
What can I do to solve and not have to reinstall everything?
Mar
may be that in the various files there is one for example deformed with the fem license.
now the file is deformed and when you save you miss the license.
It's an idea.
It's more than a week I don't use fem.
I have a folder of 24giga with 120 folders that contain files and folders.
the problem is on any cat file in any folder: there are also pdf dxf xls etc but those work well
Try to create a new catproduct with a new catpart.
then create a new catdrawing of the catproduct and save it in one of those existing cards.
If it's okay.
if you do not pass hau an evtl problem in the path of under folders.
then enter into the new catproduct a subset of the existing ones.
update the design of the new catproduct and save.
go on like this until you find the problem.
other solution:
open the main catproduct and in the logical tree eliminate half of the existing components.
save and see if it passes.
if it occurs with a new save to save the other half. This should blow up the problem.
By always halving the components of logical slander you should identify the problem.
I repeat: I believe it is because of some deformed files or using an unavailable license
Let me know, okay?
first delete all settings and try again.
you never know ... maybe they are corrupt settings
or go to tool options and in one of the many registers you will find the way to rescue.
But before you delete them you make a backup....
I made the following test:
I created a part and saved on the desktop several times successfully.
saved the same part in the main folder from 24giga several times successfully
saved the same part in one of the 120 internal subfolders: and here is the problem.
the first rescue works but then does not save anymore.
I have repeated the same procedure for another 3 of the 120 subfolders and the result is equal: the first rescue ok but then it no longer saves.
Mar
I did a further test:
I cut one of the 120 subfolders that don't work by moving it to the desktop.
saving content files works repeatedly without problems.
Where's the hippo? ? ?
I move all 24 giga in a new main folder?
What happened?
Mar
I tried to move some subfolders to a new folder but the problem is reappeared.
the difference is that if I go to the desktop everything works.
I discovered that the problem is dropbox: in fact the folder incriminated by 24 giga is inside the dropbox folder. other cat folders inside dropbox do not work, so the fault is dropbox.
in fact the desktop is not in the dropbox folder.
conclusion the problem is of dropbox not of catia.
Mar
no that catia loses the path of dropbox ...
if you have a catproduct saved on dropbox when you use save management what appears in the window?
can you post in readable ways the paths indicated?
maybe the first save on dropbox works because you look for it manually but then when reopening it does not find the various links as instead on your desktop.
dropbox is not physically a present disk.
maybe somewhere there is written that catia does not support the use of dropbox...
I found something else.
the laptop also connected to dropbox and with the same version of catia works perfectly.
for two years I use dropbox with catia without problems, and now in the light of the laptop maybe it is an installation problem on the pc that does not occur on the laptop.
cross the tests.
save with pc on dropbox and save with notebook always on dropbox and always in the same folder.
then verify the results.
If you do the same test with office documents, what's up?
try to isolate, exclude some leads, clues.
I can't help you so much.
are old-fashioned and conservative.
only on disks?
Let me know.
I think it's a waste of time.
those of the drobox don't even know how to write casket and what it's for.
after a long run and spring will tell you that the fault is catia while ds will say that it is not expected to use in dropbox chain.
They're gonna dump them.
If you need a practical solution I would opt to save on physical disk.
Staff online
