inclined plane representation
  • Thread starter Thread starter Melman89
Melman89
Hello everyone, I have a little problem with a table.
the particular is composed of simple geometries but presents in the upper part a double inclination, how should I represent it?
I can't figure out how I have to quote the high part... I hope someone can give me some disappointments.
I thank in advance all those who will give me an explanation.
with auxiliary views as from image.
But not using I create I have no idea what commands you should use, if that's your question.
the question was not related to how to do it in creo, it was just at the level of views because I do not understand how to indicate the various inclinations, because if I had to do it with a frieze I do not know how to indicate them.
another thing, if at the holes in the top, you want to give references to the low hole, how could I do?
the question was not related to how to create
you opened the discussion in the I create section so you think the subject of the problem is the software.
I don't understand how to indicate the various inclinations, because if I had to do it with a milling mill I don't know how to tell them.
as indicated in the image.
If at the holes in the upper part, you want to give references to the low hole, how could I do?
quotating the center of the holes on the external face (the one from where the tip will enter) on the axes x, y and z
