I created my side template with plan orientation as from imagewhen I create a new part though using this template opens me with this orientationNot that it's a big problem, but I don't understand why he has this behavior.
Does anyone have any idea where to set the initial opening of the template?
but if you type f6, how does the model appear?? in the template you only turned it and saved it or you redefine the f6 in the
Your view?
when you do --> new file , will you activate your view by default??
If I type f6 the model goes to place, it appears in perspective.
When I create a new part with my template I activate the view I created.
I miss the speech of redefining f6. I create a part, I open the front-oriented blank file. If click f6 it is oriented on perspective. I'd like it to be in perspective since you create the new part.
do this again:
-open the template and delete all views except the master
- Hello.
-create a new view and make it active (check mark)
- orientate the cube
- Hello.
nothing to do, there is the new view but always opens with front orientation when I create the new part while if I open the template the orientation is prospective
