integration exel - inventor 2011
  • Thread starter Thread starter Erik77
Erik77
good morning and good holidays to all (at least to those who do it)
I'm colliding with a problem I fear has no solution, at least, I haven't found it yet and I'm losing hope.
The situation is this:
the various ipt and iam files we use in the company are customized iproperty zeppi; designation en, designation en, surface treatment en, surface treatment
fields that for each individual file must be hand-written each time,
My purpose was to automate the process as much as possible.
the idea/hope was to have a table of exel with all names, superficial treatments etc etc. in Italian and English and with some simple search function select the first in a drop-down menu find the translation in another box, all tied to inventor... .
the realization of the exel file was simple rutine, unfortunately I then discovered that the tables of exel that are connected in inventor, can contain only numerical and not text strings.
in any case texts cannot be "flagging" as export parameters. . .
Unfortunately, at this point I have no other system that does not understand programming with vb in which I am denied.
or fear of knowing your answers, but I have opened this discussion in hope that something has escaped me. .
Thank you all for your help
in your set, open the separate components and search/create your custom properties (this procedure you can avoid if in your templates the properties are already present)....read this post
this situation could be resolved by setting the templates correctly, as said by peppe, and automated with ilogic with its windows of choice
if you explain better with some examples I can see feasibility
greetings and good work
first of all thanks for the answers,
now, templates already have all iproperty set (see iprop.jpg image)
the procedure suggested by peppe the use already now,
the purpose was to have a database shared with all colleagues, a table exel already compiled with the various descriptions of the object (plate, tree, bracket....) and the relative translations, the original idea was to connect the fields of iproperty to the cells of exel ( attach the file I had created) ;
from the inventor file, I opened the table of exel and in the left drop-down menus (black bold) I chose the name, finish, treatment and closure both these values, and those in English (red bold) were copied in the file iproperty.
I tried to cuff some with ilogic but I didn't get a spider out of the hole.
According to you it is feasible to create a mask with the logics that read the black bold values from the table of exel and allow me to choose the correct wording, therefore you look for the correspondent in English and write the values in iproperty?
thanks x the help, very kind
  • DATI.rar
    DATI.rar
I have long been using ipropwiz and I have verified that you can do, the only problem is that on two stations it works me and on a no. computers are identical.
in any case it is possible to download a time version that lasts 15 days if you install and it proves that it works all right then you can buy
I tried to install ipropwiz, but it doesn't work, the install, at the first opening ask me the folder x the configuration files, it doesn't exist, the creo... the program opens but is empty, it doesn't give me the chance to do anything.. .
It'll be fate that I can't automate is what...
if you go to the add-ons menu of inventor, you will see the ipropwiz voice and the ipropviz setup voice. on the setup you can click the variables to display and compose lists
Good morning.
thanks to all for the help, but also with ipropwiz I can not make him do what I want... I think I will take the opportunity to learn a little visual, maybe something good comes out.. .
with ilogic you can read an excelle file, upload rows to a multi-value varivile, create a quick choice window, and match the variables you want, the translation.
I give him a look at the weekend, but you investigate...
I refer to a discussion that I put in a few days ago http://www.cad3d.it/forum1/showthread.php?t=27547 that should have the purpose of understanding the possibilities of ilogic, see what you can do, take hints and suggest solutions.
I don't know if this type of discussion can be in this forum or if it has to be placed elsewhere. I believe it is useful to iventorians
thank you x the interest, they rejoin me too, despite being ignorant in this matter.
I think it would be worth opening a special tread on the possibilities of programming, to many could be interested in creating automatisms x software cad, with ilogic for inventor but also with vb.
good weekend to all and again thanks
I threw down a few lines with ilogics and got a window of choice of the name, surface treatment and heat treatment. selecting the voices of the three boxes these are translated and are attributed simultaneously to custom propety that you will use in some way.
everything is in a template and a xls file reorganized on 3 sheets
I do not know if the rules of the forum allow to allegarle to an answer, if some moderator gives me indications I can allegarle
you can't attach files to the answers in pm, but since you can interest everyone, attach in this 3ad...:smile:
I copied the rule from 2012 with which I created it and the 2011 version.
Unfortunately some features are not present on 2011 as the possibility to create a form with all the choices I need.
on 2011 I circumvented the problem with three listbox windows with which to make the choices.
I attach the file "model with rule" and the file "prova.xls" to put in the same folder, if the xls file is placed in a different folder indicate the path within the rule (browswr of the rules, edit rule, see comments).
open the file to activate the rule go in "management" and click in the ilogic group the icon "itrigger".
it is possible to put this command more at your fingertips with customise commands or to associate it with a quick selection key.
in the model there are no voices in Italian, but once the rule has been performed the voices remain loaded in variables with multiple values, in any case by re-executing the rule are again loaded and then updated by the xls file.
once the rule checks in custom properties the values that have updated.
greetings to all now I go to a nice fish dinner:smile:
Good evening,
I have seen only now the answer because I am not at work and I do not connect to the mail very often.
As soon as I'm in the office I'll try the file you prepared but I'm sure there's no problem.
Thank you for the beat, I would have spent months... learning how to use vb. (which I may try to do the same)
Thank you very much for your help.
