inventor on virtual machine
  • Thread starter Thread starter design77
design77
Good morning to all, good start for those who have already begun.
I have the following problem, in order to avoid burdens of the operating system I have created a virut machine in which I went to install inventor 2008 , everything works but when I open files I blow all the menu bars , I think the problem is to be searched in the virtual video card that seems to have only 128 mb ,
the sitema and wimlite with xp mode.
advice and experiences?
hi design77, try with wmware with special machine with simulated graphics card with directx. go to the website http://www.easyvmx.com/ and create the virtual machine as indicated and abounds on the features.
so the only way is to use win ware, wimlite and virtualbox is not possible, I use these two currently.
is wmware paid or I remember badly?
Is there a free version?
the viewer is free, you register to download it but it is free wmware player! and the virtual machine you create it from the site I wrote above. install everything, and then install the s.o. on the virtual machine and install inventor.
I tried to do as you told me, but to install the operating site in the car as I have to do?
can use the xp mode package released by microsoft
eye that xp mode is as fast as a wounded bradipe, I tried it and it is unnerving. . .
Start the virtual vacuum machine, insert the xp cd or the sistma you want to install, it's okay also an iso, up there is a menu to decide what to point. . and so begins installation, no more or less as installing a physical pc.
xp mode....forget it:finger:
Good morning
I have to buy a laptop to run some 3d drawing programs, including inventor11;
Unfortunately, we know that it is certified only for winxp 32bit.
I thought I would mount 2 disks on the new machine, so I had 2 separate operating systems: on the first I would put win7 64bit, on the second winxp 32bit;
on the first I would turn proe wf5, while on the second note inventor11.
for this I ask you, is it a valid solution? or recommend 1 disk only and use inventor11 with xpmode?
Good morning
:36_1_13: 2 east disk better than one :36_1_11:
Hello, everyone.
I would like to try installing an old version of inventor 2011 on virtual machine on linux. just for the curiosity to see if it is feasible. I see someone like mechanicalmg tried to do it. Does anyone have results? travel the 3d? Thanks for the answers.
in its time i.e. 7/8 years ago did not make more than anything for the video card shared by physical machine on virtual...magari now it is better
